Activity › Forums › Blackmagic Design › Multibridge question.
Posted by Rafal Pyszka on April 16, 2008 at 7:18 amOur corporation wants to buy Decklink Multibridge. Is Multibridge full compatible with HDCAM SR ? We want to authoring blu-ray this. Which software is the best for capture from Hdcam SR?
Del Chapple replied 18 years, 5 months ago 6 Members · 6 Replies -
Bernhard Rummel
April 16, 2008 at 6:24 pmhi,
i have no experience capturing from hdcam-sr, but we use the MB-Pro for hdcam (via HD-SDI to 10Bit 4:2:2 YUV).
but i think there isn´t a big problem with hdcam-sr, because the MB has also dual link HD-SDI. so you should be able to capture uncompressed 10Bit RGB 4:4:4 with Premiere Pro. you just need a fast raid… 😉
if someone has hands-on experiences with hdcam-SR, i would be also interested in.
best,
bernhard.
Chris Borjis
April 16, 2008 at 10:24 pmunless I’m mistaken there are multibridge models with only 1 HD-SDI spigot that cannot ingest dual link 4:4:4 from HDCAM-SR.
I have the multibridge extreme and I know for a fact it CAN do dual link 4:4:4 as it has 2 HD-SDI spigots.
just make sure you whatever you buy has dual link and your good to go.
Rafal Pyszka
April 17, 2008 at 8:40 amWe want to buy Multibridge Eclipse. Is this appropriate to use with HDCAM SR??
Margus Voll
April 21, 2008 at 4:53 amHi.
Eclipse is very appropriate.
https://www.blackmagic-design.com/products/multibridge/techspecs/
I have Pro version and it is also really good for that if you take look at the specs.
Margus
Kristian Lam
April 22, 2008 at 1:16 amHi,
All current Multibridge models support 4:4:4 Dual Link using either 2 BNC cables OR 1 single BNC cable via 3 Gb/s SDI. This means that if you don’t need that many AES/EBU audio IOs, the Multibridge Pro will be sufficient for working with the HDCAM SR.
regards
Kristian Lam
Blackmagic Design -
Del Chapple
April 23, 2008 at 9:07 pmHDCamSR, if you have the 444 board, installed will easily crossconvert the signal to 422. 444 would be overkill for Bluray authoring anyhoo..
del
you cant hear my inner voice scream… can you..?
