Activity Forums Blackmagic Design Multibridge Pro with Premiere CS6.01 Mac — no HD monitoring
  • Multibridge Pro with Premiere CS6.01 Mac — no HD monitoring
    Posted by Adam Levine on June 14, 2012 at 7:03 am
    Mac Pro 5,1
    32 GB RAM
    OS 10.7.4
    CS6.01
    Footage from Canon 5D 1080p24
    BMD Desktop Video 9.5.2 (installed last)
    Trying to cut my first project on Premiere CS6. It was shot on the 5D, and I thought I’d try to take advantage of not having to transcode all the dailies to ProRes for FCP. Footage imports fine, and I can see it play fine in APP on it’s own or in a sequence.
    Picture does not play out the Multibridge when processing is off, but if I downrez the picture to SD in System Preferences->BMD, it plays fine. Sound plays fine either way.
    Any thoughts?
    Nate Rich replied 14 years ago 2 Members · 1 Reply
  • Nate Rich
    September 10, 2012 at 8:54 pm
    Did you ever get this fixed? I’ve got the same issues… When I play out 1080p23.98 I get wacky quadrant type output, with the video up in the top right corner. When I play 1080i60 its ‘fine’ until I render, but then gets squeezed down to the center of the monitor. When I down convert to SD via BM, it plays out fine in SD.
