Activity › Forums › Blackmagic Design › Multibridge Pro vs. Multibridge Extreme —– Same?
Posted by Jonathan Steinhauser on December 8, 2007 at 6:52 amAre these two BMD products essentially the same except for the HDMI vs DVI-D ins and outs? The Multibridge Extreme still runs about $ 2500 at B & H and the Multibridge Pro is around $1500 street. I can’t find any info on the MBE on BMD’s site, just info on the MBpro. Was the MBE a precursor to the MBpro?
Any info helpful.
J….
Jonathan Steinhauser replied 18 years, 9 months ago 4 Members · 6 Replies -
Geir Ove thorsveen
December 10, 2007 at 9:11 amBefore their last hardware upgrade of their multibridge line, the Multibridge Pro had some restrictions to what formats it could handle, whereas the Multibridge Extreme could do up to 10-bit 4:4:4 (if memory serves me right). Both these models have been replaced by the new Multibridge Pro and Multibridge Eclipse models, which both have dual-link and 3 Gb/s capacity.
The older hardware editions also don’t come with HDMI inputs. But have HDMI (Pro) and DVI (Extreme) monitor outputs.
This is from memory, so it should be taken with a grain of salt, but I don’t think there are any reason for buying an old Extreme model over a new Pro.
Geir.
December 10, 2007 at 7:17 pmThanks for the info. You summarized more or less what I was able to find out even without info on the Multi Extreme on the BMD website. It is as if it has dissappeared from their view.
Kristian Lam
December 12, 2007 at 2:53 amHi Jonathan,
We’re no longer producing the Multibridge Extreme which is why it’s no longer on our website.
The main differences between Multibridge Pro and Extreme:
Pro | Extreme
=======================================HDMI (input/output) | DVI (output only)
2K I/O via 3 Gb/s SDI | 2K monitoring via DVI to 30″
Software downconversion| Hardware downversionregards
Kristian Lam
Blackmagic Design -
December 12, 2007 at 3:16 amWhat is the process / software needed for updating the firmware in a MBE? Is it available on your site?
Chris Paul
December 19, 2007 at 11:41 pmOne huge difference for me is the split down conversion. The MBE will output HD and SD simultaneously. I do spots in both HD and SD- it’s really helpful to see how both version will look as you go.
Chris Paul
POV -
December 20, 2007 at 6:51 amI was able to grab a MBE for about 2/3 of the cost of the MBPro on Ebay and it is working out very well… The split HD SD monitoring that you speak of is a bonus…. Thanks.
