Activity Forums Blackmagic Design Multibridge Pro SDi output problem
  • Multibridge Pro SDi output problem
    Posted by Adam Jenns on May 20, 2008 at 1:31 pm
    Hi All,
    I’m having some issues with the sdi output from my multibridge pro. When I go sdi out of the breakout box [with a decklink pal timeline] into the sdi input of our digibeta or hd cam deck the picture is a very vivid green and purple colour. The hdmi and composite outputs seem fine.
    It sometimes sorts itself out with several restarts but not ideal. I have installed the latest firmware and software.
    Thanks in advance.
    adam
    Joshua Helling replied 18 years, 4 months ago 3 Members · 7 Replies
  • 7 Replies
  • Margus Voll
    May 20, 2008 at 1:43 pm
    Hi.
    Do you have in house sync ?
    Margus
    https://iconstudios.eu
  • Adam Jenns
    May 20, 2008 at 1:55 pm
    No, is that my issue? Will i need an external sync generator?
    thanks. adam
    MAINFRAME [design, motion graphics animation]
    24-28a Hatton Wall, London, EC1N 8JH
    T :: 020 7404 1666
    F :: 020 7404 2666
    E :: adam@mainframe.co.uk
    W :: https://www.mainframe.co.uk
  • Margus Voll
    May 20, 2008 at 1:57 pm
    It might.
    If you could borrow one for testing.
    Margus
  • Margus Voll
    May 20, 2008 at 2:00 pm
    I’d also chek IRE setting from system prefs (mac).
    I’m not sure if this mathers with SDI but i’d definetly try.
    Margus
  • Adam Jenns
    May 20, 2008 at 2:07 pm
    Thanks Margus, I think i had some of my system prefs wrong. I’ve now unchecked the “select dual link 4:4:4 on video output’ and that has given me the option to ‘select black ref on video output’ which has sorted the problem.
    Best regards, adam
    T :: 020 7404 1666
    F :: 020 7404 2666
  • Margus Voll
    May 20, 2008 at 2:08 pm
    Usually this is the case 🙂 you just have to see your prefs.
    Margus
  • Joshua Helling
    May 23, 2008 at 6:02 pm
    Hey guys,
    A quick note here. IRE wouldn’t effect this much, but the color sounds definately like the device was in 4:4:4 mode.
    There was a bug (just fixed in 6.7) that was causing the boards to become de-synced to the control panel, and that often meant that you had to toggle the control panel settings to get them to realign. But that is fixed now.
    So about the “set black ref on video out in capture” setting you toggled, that basically creates a reference to use with your deck while in capture mode. While you probably don’t need to use the setting, there is definately no problem with having it turned on.
    Sincerely,
    Joshua
    Director of Support
    Blackmagic Design Inc.
