Activity Forums Blackmagic Design Multibridge Pro SD to HD conversion
  • Multibridge Pro SD to HD conversion
    Posted by Katherine on February 28, 2007 at 10:37 pm
    I have Blackmagic 10 bit 29.97 media in FCP 5.1.4 that I want to convert to Blackmagic HDTV 1080p 24 10 bit. I have access to a Multibridge Pro. If I lay off to digibeta, can I upconvert the media by recapturing it through the Multibridge Pro? If so, how. When I try to recapture the media using the HDTV codec, I get the “no video input” sign. I am going out of the deck SDI. I have set the DeckLink to SDI input and to convert SD to HD on input. Is the fact that I am doing a frame rate conversion along with the SD to HD conversion a problem?
    Any ideas?
    Or any ideas on other ways I can convert this media both in size and frame rate?
    Katherine replied 19 years, 6 months ago 1 Member · 0 Replies
  • 0 Replies
