Activity Forums Blackmagic Design Multibridge Pro Output to Apple 23″ Display (via HDMI – DVI)
  • Multibridge Pro Output to Apple 23″ Display (via HDMI – DVI)
    Posted by Stephen Bull on July 21, 2006 at 1:58 am
    Hi Guys,
    Has anyone out there tried outputting to an Apple 23″ LCD display, via the HDMI output and a HDMI to DVI adapter?
    In theory I can not imagine why it wouldn’t work, but I just wanted to check before we went any further with the purchase. I realise the Multibridge Extreme has a built in DVI output, but we can’t justify the extra $1600.00 (AU) when we are just using it as a stand alone converter.
    I have copied below the specs of the HDMI to DVI converter I was thinking of using.
    DVI-D Female to HDMI Male Adapter Cable, 0.2m
    Converts a DVI cable for use with an HDMI interface!
    Connects an HDMI digital display to a device with a DVI-D display output
    Allows DVI-D signal cables to be connected to a display with an HDMI input
    This adapter supports digital signals only, analogue connections are not supported
    Connectors: DVI-D Female to HDMI Male
    Length: 20cm
    Appreciate any suggestions or ideas you might have.
    Cheers
    Steve
    Stephen Bull replied 20 years, 1 month ago 2 Members · 2 Replies
