Activity › Forums › Blackmagic Design › Multibridge Pro or DeckLink HD Extreme + HDLink
  • Multibridge Pro or DeckLink HD Extreme + HDLink
    Posted by Margus Voll on August 15, 2007 at 5:25 am
    Hi.
    I wonder is there is eny big difference in which way should i go ?
    Generally it seems that i get the same result in either combination
    Multibridge Pro or DeckLink HD Extreme + HDLink.
    I work now with SD but from time to time i also start doing HD.
    Analogue connections are important with my Beta SP.
    Eny ideas or +/- ‘ses.
    Margus
    https://iconstudios.eu
    Margus Voll replied 19 years, 1 month ago 2 Members · 4 Replies
  • Margus Voll
    August 16, 2007 at 5:48 am
    Main difference i see is that specs tell bit different for color sampling but it feels like i missed something.
    Can enyone comment on that?
    Generally all connections are the same ?
    Margus
  • Kristian Lam
    August 16, 2007 at 6:20 am
    Hi
    Not really. Multibridge Pro has HDMI output so you won’t be able to use a DVI monitor. If you’re using a DVI computer display, use HD Extreme + HDLink. If you’re going for a HDMI display to monitor, then Multibridge Pro.
    regards
    Kristian Lam
    Blackmagic Design
  • Margus Voll
    August 16, 2007 at 7:35 am
    Hi.
    Thanks for the fast response.
    It raises just one question:
    I’m planing to do some SD work also so is there eny significant difference what to use 42″ LCD tv or plasma with hdmi or Dell 3007WFP-HC with DVI.
    Margus
  • Margus Voll
    August 19, 2007 at 10:02 am
    Hi again.
    One thing that i came up with is that HD Link lets you use LUT
    which multibridge Pro do not let you do or do i missunderestand again :)?
    Margus
