Activity › Forums › Blackmagic Design › Multibridge Pro not recognized.
  • Multibridge Pro not recognized.
    Posted by Shane Ross on August 16, 2007 at 6:32 pm
    I have a Mac Pro 2.66Ghz machine with a Multibridge Pro card and BOB installed…running FCP 5.1.4. I downloaded and installed the MULTIBRIDGE 6.4 UNIVERSAL drivers on this machine…yet I can’t get it to work.
    I was sent this computer and capture card as an evaluation unit to use in testing a hard drive RAID array (my machine is PCI-x, and the array is PCIe only, so I was supplied with a computer and capture card to do tests).
    So I installed the drivers, connected the card via the thick PCI Express lane cable…and connected it to a deck and monitor. Now, the test to see if all is working is to go into the DISPLAYS system pref and see if you can see the external monitor. I cannot. FCP also does not detect the card so…
    What am I to do? I see that the BOB has a spot for power, but I don’t have an adapter. Is that required? Or only for the conversion aspects of the card?
    Shane
    Littlefrog Post
    http://www.lfhd.net
    Kristian Lam replied 19 years, 1 month ago 2 Members · 3 Replies
  • Kristian Lam
    August 16, 2007 at 11:48 pm
    Shane,
    The Multibridge Pro requires external power regardless of it being in standalone conversion mode or when connected to your Mac via PCI Express. An external power supply should come with the unit.
    regards
    Kristian Lam
    Blackmagic Design
  • Shane Ross
    August 17, 2007 at 3:04 am
    Thanks Kristan.
    Now I have to wait for it to arrive. GAH!
    Shane
    Littlefrog Post
    http://www.lfhd.net
  • Kristian Lam
    August 17, 2007 at 4:04 am
    Ok. You can also contact support[at]blackmagic-design.com if you run into any issues.
    regards
    Kristian Lam
    Blackmagic Design
