Activity Forums Blackmagic Design MultiBridge Pro Input Support?
  • MultiBridge Pro Input Support?
    Posted by Scott Ferril on May 25, 2008 at 7:02 pm
    I have a new Multibridge Pro that doesn’t seem to see any video, HD SDI and analog tested with same results. Nothing passes through. The output works fine from Final Cut Pro. I’ve tried stand alone converter mode, as well as input capture through PCIe. I have many decklink cards and other Blackmagic products that work fine.
    This is the latest mac 8 core, latest updates. There was a hardware upgrade that it requested twice, not sure if there’s anywy to check that it wen through… Or is there a simple switch I’m not seeing?
    Thanks, Scott
    Scott Ferril replied 18 years, 3 months ago 2 Members · 2 Replies
  • Adam Jenns
    May 29, 2008 at 3:01 pm
    Hi Scott, can you see the pcie card in the system profiller? I’ve just had a dodgy one replaced by BM.
    Also does an extra desktop appear in your display configuration?
    Cheers, adam
    MAINFRAME [design, motion graphics animation]
    24-28a Hatton Wall, London, EC1N 8JH
    T :: 020 7404 1666
    F :: 020 7404 2666
    E :: adam@mainframe.co.uk
    W :: https://www.mainframe.co.uk
  • Scott Ferril
    May 30, 2008 at 6:55 am
    Not at first, the PCIe card was a bit loose. I fixed that, at least to the point of it showing up, and the output from FCP worked. It did ask for a firmware update when I tried to use the stand alone mode to test. I did that twice and neither were clear if it update. A couple days later I tried it and it worked, no reason why, just had sat off over a couple days. Think the firmware update set in. Not sure. It seems to work now. Wish I knew what it was…
    Thanks, scott
