Activity › Forums › Blackmagic Design › Multibridge Pro HDMI Output
  • Multibridge Pro HDMI Output
    Posted by Afc Dmc on August 29, 2007 at 2:54 pm
    Hi I have a Multibridge Pro 6.4 connected to a Mac Pro 2.66 and FCS 2(FCP 6) I shoot some footage with the HVX200 in 720 24pn with a P2Card the problem that I am having is I can’t see full playback in my Vizio LCD monitor. The MB is connected to the Vizio via HDMI. What playback setting I need to be able to view full playback in both the computer monitor and the Vizio LCD?? I only see stills in the Vizio!!! If I playback I can see it in the FCP viewer but in the Vizio I only see Freeze Frames!! if I scrub I can see the frames but not in full playbak!! I set the view menu setting to All Frames but still no full playbak!! Can Someone point me to the right Settings to be able to do this!! Thanks!!
    Afc Dmc replied 19 years ago 2 Members · 3 Replies
  • Mike Herod
    August 29, 2007 at 9:04 pm
    I have the same problem…I only see a still frame when parked in the timeline. When I play I get a black screen but audio plays fine. HDV footage.
  • Mike Herod
    August 29, 2007 at 9:14 pm
    Figured it out, go to “easy set up” select HD as format, then select appropiate Blackmagic rate and use.
    Mike
  • Afc Dmc
    September 12, 2007 at 3:40 pm
    I figure it out!!! I had to put the output precessing in the DEcklink Systme preference to no!!! But for some reason when I put the output processing to 720p to 1080i and the videoplayback in FCP to Blackamagic 720p 59.9hz 8 bit I get some studering in Audio and no video!!! does this is normal? also when I put the HD to SD Anamorphic 16:9 in the System preferences I got Some weird doble image and image distortion!! Does this is related to the Vicio LCD or is a Multibridge problem?
