Activity Forums Blackmagic Design multibridge pro and panasonic varicam AJ-HDC27HE
  • multibridge pro and panasonic varicam AJ-HDC27HE
    Posted by Emiliano Ferrara on March 16, 2008 at 8:32 pm
    hi everybody.
    i’m from italy then in pal world.
    i just purchased a BLACKMAGIC DESIGN MULTIBRIDGE PRO and i edit with finalcut pro 6.
    i’m going to start a project for a long documentary film shooted with the panasonic varicam AJ-HDC27HE camera in 720 25p
    it’s first time i work whit this format then i have some question:
    -is possible capture directly from the camera via hd/sdi output?
    -wich is the workflow? i mean wich is correct easy setup to use in finalcut?
    -how can i, at the end of editing, output pal sd 25i?
    -can i output to tape in 25p using hd/sdi out of multibridge to in hd/sdi of AJ-HDC27HE?
    -how manage clips shooted in variable frame rate, i mean slow motion or fast motion clip?
    tnx in advance.
    emiliano
    Emiliano Ferrara replied 18 years, 5 months ago 1 Member · 0 Replies
  • 0 Replies
