Activity › Forums › Blackmagic Design › Multibridge pro 2 and analogue audio in
  • Multibridge pro 2 and analogue audio in
    Posted by Margus Voll on July 21, 2008 at 7:36 pm
    Hi.
    I wonder if somebody has the experience with newer drivers if audio input 2 analogue channels can
    be mapped as inputs for sountrac pro.
    Today i only managed to record as log and capture only without video.
    I have sync and video feed from my beta sp.
    Ideally i would like to record to STP.
    Eny ideas.
    Margus
    https://iconstudios.eu
    John Richard replied 14 years, 10 months ago 3 Members · 5 Replies
  • Luke Maslen
    July 23, 2008 at 4:00 am
    Hi Margus,
    Multibridge and DeckLink cards require that you capture video with audio because they are fundamentally SDI products where audio is embedded in the video signal. If there is no video, there is nothing to carry the audio. SoundTrack Pro does not capture video so you can’t use it to capture audio with a Multibridge. You can play back audio with SoundTrack Pro and your Multibridge and we have an old support note about that on our website named Can I use SoundTrack Pro™ with DeckLink cards?.
    Regards,
    Luke Maslen
    Blackmagic Design
  • Margus Voll
    July 23, 2008 at 9:03 am
    Hi.
    Yes i use STP all the time with Multibridge and it is perfect.
    Would it be in theory possible to make driver that just takes audio and map it to system ? With FCP now i capture just audio and only 1 track and have no video at all. So i wonder if it would be possible to capture just audio like that. generally i see that it should be possible to get audio out of sdi so to say and send video to NULL device. I assume that sync and ref (component blank) video is inserted but only audio is captured.
    Would this be possible in theory?
    I underestand that it would need a lot of programming and R&D but i wonder if it would be possible in theory.
    My goal would be to skip additional audio devices in my studio as possible 🙂
    Margus
  • Luke Maslen
    July 24, 2008 at 6:39 am
    Hi Margus,
    Yes, I’m pretty sure that would be possible in theory although one never knows until you try! I know we’ve received this suggestion before so I’ll raise it again with the engineers to see if we could add audio-only support.
    Regards,
    Luke Maslen
    Blackmagic Design
  • Margus Voll
    July 24, 2008 at 7:48 pm
    Thanks.
    I have my hopes up 🙂
    Margus
  • John Richard
    November 12, 2011 at 10:36 pm
    Did this issue ever get resolved?
    With all the NLE’s have a great Voiceover options going direct to the timeline as well as apps like Audition, it surely seems that Multibridge aught to be able to record audio only with a video carrier.
    http://www.LightPrism.TV
