Activity › Forums › Blackmagic Design › Multibridge HD YUV to SDI conversion field order wrong
  • Multibridge HD YUV to SDI conversion field order wrong
    Posted by Gunter Puszkar on June 9, 2005 at 5:33 pm
    I attached an analog YUV HD Signal from a Sony FX1 to the Multibridge, then I connected the HDSDI Signal to a Sony BVM-D24 HD Monitor and I saw a wrong field order.
    The BMD Multibridge was flashed with the latest version from today (V1.4) and then powered off as recommended by BMD.
    Has anyone else experienced this problem? Was the firmware upgrade went wrong? How can I do it again. The software tools is just a joke… (e.g. a help menu with an about function is missing)
    By the way, the signal quality at the Multibridge wasn’t that good as the LMP HD-YUV > HD-SDI Converter from LuxMediaPlan.
    cheers.
    Nuddellon
    Gunter Puszkar replied 21 years, 3 months ago 2 Members · 2 Replies
  • Sean Oneil
    June 9, 2005 at 6:24 pm
    How old is your Multibridge? There was a recall because of problems with analog component input.
  • Gunter Puszkar
    June 9, 2005 at 6:42 pm
    I received it today by a local reseller…. after the shipping was delayed.
    Nuddellon.
