Activity Forums Blackmagic Design Multibridge Extreme….Composite Input??
  • Multibridge Extreme….Composite Input??
    Posted by Chris Borjis on March 21, 2006 at 9:04 pm
    It looks like the bnc connector on the back of the unit has an NTSC/PAL output…fair enough.
    BUT
    The connector below is labeled NTSC/PAL/REF input.
    We have black burst plugged into it now. Are we supposed to unplug the REF signal and plug in composite video from a vcr if I need to capture a vhs clip?
    This seems a little strange. why not have a separate synch input?
    anyone?
    Chris Borjis replied 20 years, 6 months ago 2 Members · 2 Replies
  • Kristian Lam
    March 21, 2006 at 10:44 pm
    When you select Composite as an input option in the Multibridge Extreme, Ref input is switched off.
    regards
    Kristian Lam
    Blackmagic Design
  • Chris Borjis
    March 21, 2006 at 11:29 pm
    ok Thanks.
