Activity › Forums › Blackmagic Design › Multibridge Extreme – which platform
  • Multibridge Extreme – which platform
    Posted by Margus Voll on August 16, 2006 at 5:17 pm
    Hi.
    I have task to build system that can handle “HD”.
    Source would be Panasonic P2 or Canon XL H1 for now.
    My preference says Canon because of SDI output.
    P2 needs additional conversion yes ?
    Final output is Beta SP now.
    Multibridges advantage for me would be analog connections
    and direct monitoring from dedicated LCD.
    Other option would be DL HD Extreme with HD link.
    For analog connection to Beta SP there should be standalone Multibridge etc.
    Limitation is only 1 SDI input from future point of expanding.
    My main concerne is if i should go with MAC or AMD Opteron based PC.
    I know Multibridge handles both platforms but is there
    eny preffered way?
    Margus.
    Margus Voll replied 20 years, 1 month ago 3 Members · 4 Replies
  • Bob Zelin
    August 16, 2006 at 8:29 pm
    I have never seen a question like this. When you ask “should I choose MAC or PC” – you are basically asking – “should I choose Final Cut Pro (on MAC) or Adobe Premier (on PC). The decision of what software you should use to edit with is VERY IMPORTANT and a personal preference. Your editor should make this decision, based on what he likes to edit with.
    Bob Zelin
  • Margus Voll
    August 16, 2006 at 9:32 pm
    Hi.
    I think i will be this editor. Now i use DL Extreme with prem pro.
    Future might bring P2 material and there as i underestand mac
    has advantages but is not true uncompressed what i seek.
    My goal would be Multibridge but i do not know how to integrate
    P2 if it comes. With SDI input it seems clear and there is just
    if edit with prem on fcp.
    Other problem is there how to make field recorder so to say.
    Machine that takes SDI from lets say canon camera and records
    it to HDD directly. With P2 it is simpler there.
    Eny ideas?
    Margus.
  • Kristian Lam
    August 17, 2006 at 4:42 am
    If you’re going to be dealing with P2 and DVCPRO HD in general, go with the Mac. We current do not support DVCPRO HD on the PC.
    regards
    Kristian Lam
    Blackmagic Design
  • Margus Voll
    August 17, 2006 at 6:22 am
    Ho does P2 workflow work on mac?
    Material has to be converted or can it be used directly ie.
    material stays in its native P2 format in fcp but shows through
    BM board.
    Margus.
