Activity › Forums › Blackmagic Design › Multibridge Extreme ref. video
  • Multibridge Extreme ref. video
    Posted by Miro Simeg on May 3, 2006 at 4:01 pm
    Hi there,
    I work on Mac G5 Quad + FCP and I have problems connecting Multibridge Extreme with Sony UVW-1800p. I don’t know what to do with ref. video problem and I can’t export from FCP to Sony deck (maybe it’s the same problem).
    What should I do?
    Do I need blackburst generator? If so, which one? Where can I get it?
    Thank you
    Miro
    Chris Borjis replied 20 years, 4 months ago 3 Members · 3 Replies
  • Kristian Lam
    May 4, 2006 at 12:49 am
    A blackburst generator for the UVW-1800 is recommended.
    Alternatively, (sorry Bob!) you can use this temporary workaround.
    Connect the Y output of the Multibridge Extreme to the REF IN of the deck. Turn off the 75 ohm switch and take the REF loop out and connect it back to the Y component input of the deck.
    regards
    Kristian Lam
    Blackmagic Design
  • Miro Simeg
    May 4, 2006 at 12:35 pm
    Tnx Kristian, already tried that. The result is this:
    – UVW-1800 is telling me that “A BLACK/WHITE SIGNAL IS BEING USED FOR REF VIDEO. SUPPLY A COLOR SIGNAL WHEN USING THE COMPOSITE OUT OR S-VIDEO OUT.” So I guess thats ok 🙂
    The other problem is that I can’t get video signal from FCP to Beta deck. I can’t find a problem… On a monitor (connected to Beta deck) I have a desktop background form computer, so I guess that video signal is OK, but I can’t get video or audio from FCP. And when I try to “Edit to tape” from FCP I get video out, but it looks like a “Purple haze” or rather “purple noise”. I’ve never seen anything like that.
    Any ideas? Anyone?
    2 more questions about the same thing:
    1. what is NTSC/PAL REF IN on Multibridge for?
    2. I have Extreme HD card in PC. Does it have ref video signal and can I connect it somehow to Beta deck?
  • Chris Borjis
    May 5, 2006 at 4:14 pm
    [Miro Simeg] “1. what is NTSC/PAL REF IN on Multibridge for?”
    Thats your composite video input that also doubles as your black burst input.
    I connected it to a patch bay normaled to a black burst cable, so it gets black burst when no composite video is coming in, but switches to composite and turns off the blackburst when a cable is plugged in.
