Activity › Forums › Blackmagic Design › Multibridge Extreme PCIe problem
Nate Owens
January 20, 2009 at 2:21 pmHello All! Just got back in the office this AM. On friday, I contacted BM tech support and after determining that I was still under the 3 year warranty (just barely!) they gave me an RMA to send the whole unit in for diagnosis. I will report back to this thread when I get the unit back and hopefully up and running again.
Nate
Nate Owens
Multi-Media Operations Manager
National Baseball Hall of Fame and Museum -
Adam Levine
January 30, 2009 at 8:24 pmHi. I seem to be having much the same problem.
I’ve had a Multibridge Extreme in my G5 Quad since March, 2006. It’s always worked just fine all the way through when I pulled it out of the G5 yesterday to transfer to a Mac Pro (1st Gen) Quad Core that I got from a friend. The Mac Pro will not recognize the Multibridge no matter what I do. I have tried:
1) Reseating the card
2) Trying in Slots 3 and 4
3) Repeated uninstall/installs of driversI am running the 2nd config (16x, 1x, 4x, 4x) in the Expansion Slot Utility. There is a Sonnet E4P in slot 3.
Any thoughts on this or will this thing not work in a Mac Pro?
Adam Levine
Squeeze A Nickel Productions -
Marcia Kapustin
January 30, 2009 at 8:36 pmThanks Gene. I got back my multibridge from BlackMagic and they said that it was fine but needed the firmware to go back from standalone converter. Anyway, when I popped it in, it worked (recognized slot 4) and was fine for about 6 hours. Then the fan revved up like a motorcycle (revving up and down and up and down) and after that it just continuously crashed my Final Cut. I have sent an email back to the BlackMagic folks (who were very fast in responding and sent an RMA quickly – thanks!), and awaiting their next response. Adam, Hopefully this way helps to wake up your slot 4.
Marcia
Re: Multibridge Extreme PCIe problem
by Gene Colburn on Jan 19, 2009 at 8:57:44 pmLog on as Administrator go to HD>System>Library>Core Services and you should be able to open the Expansion Slot Utility. Setup slot 4 for 4 lane, and everything should work. You might need a cold reboot after change before it will initialize.
One caveat here would be if you have a couple of 16 lane PCIe graphics cards installed in your workstation that would be hogging all express lane resources. If so the Multibridge will never work in that con -
Adam Levine
January 30, 2009 at 9:21 pmIs there a way to force a firmware update on this thing? I thought it was just automatic when new firmware was available. Can a factory restore be performed?
Adam Levine
Nate Owens
January 30, 2009 at 9:51 pmHi All! When all was said and done, BM sent us a new BME box. They said my PCIe card was fine but there was a problem with the box itself. Adam, if you can, try to contact BM at their # on the website. It may take awhile to get through but they are very responsive to questions (at least with me!) Good luck, Nate
Nate Owens
Adam Levine
January 30, 2009 at 10:58 pmI was able to fix the problem:
Shutdown
Pull all cards but video card
Startup
Login as root
Make ESU chages
Restart
Shutdown
Put cards back
StartupEverything’s good now.
Adam Levine
