Activity Forums Blackmagic Design Multibridge Extreme lookup tables
  • Multibridge Extreme lookup tables
    Posted by Chris Borjis on March 3, 2006 at 6:26 am
    Does anyone know where the custom lookup tables are stored?
    I’d like to have my dell 24″ LCD better emulate the color as close as possible
    to my SDI CRT. (i realize it won’t be spot on, but closest possible would be nice)
    I noticed the color is a little off and I don’t believe I can
    adjust the color on the DVI-D input.
    thanks.
    Kristian Lam replied 20 years, 6 months ago 2 Members · 1 Reply
  • Kristian Lam
    March 3, 2006 at 6:45 am
    Multibridge Extreme’s DVI-D output can be adjusted. You need to go into the Blackmagic DeckLink Preferences and check the video output options. The pull down menu will have a DVI-D option. You can adjust the RGB lookup using sliders.
    regards
    Kristian Lam
    Blackmagic Design
