Activity › Forums › Blackmagic Design › Multibridge Extreme experience
  • Multibridge Extreme experience
    Posted by Chris Paul on January 23, 2006 at 6:51 pm
    Just thought some folks might be curious about how the Multibridge Extreme is working so far. Please refer to my profile for my system setup.
    I usually edit in standard def with betacam and HDV sources. The ME handles this without trouble provided that I use something close to a Blackmagic easy setup in FCP. I take Betacam out via component analog while monitoring via the simultaneous composite analog out. I take the720P HDV in several ways. FireWire direct works fine with real time mixing with the standard def video in a timeline set to Apple 10 bit uncompressed, RT unlimited setting. This gives the option of reframing shots without losing resolution. I also use switch boxes for the component analog out and RS422 deck control ports on the JVC HDV deck to bring in the HDV as other formats, usually either SD or HD100. The JVC deck does a nice job of converting 720p to 480i in either letterbox or center cut, as well as 1080i. It even up converts DV 480i to 720p! The ME converts 720p to 480i or 1080i in real time via software- I am told by Blackmagic tech support that hardware down conversion is coming.
    Most of the time I take 720p 24fps material and edit in 10 bit standard def. My customers like it better than betacam. The particularly like improvement in color correction and chroma keying I am getting over my old Cinewave. I miss some of the Cinewave’s real time ability but the Apple G5 quad more than makes up for that most of the time when unlimited RT is enabled.
    I should also say the Motion runs in real time while running FCP on the same system, even playing back on the same video monitor without conflicts. Very cool!
    The only down sides so far have been in features not yet implemented. Hardware down conversion, SD display doubling and HDMI are the most missed, although Blackmagic tech support says that they should be enabled in the next driver update or the one after.
    The bottom line for me is that my customers who are switching to HDV are very happy with my new setup and reliability has been great- no crashes so for.
    Sorry to ramble so long but I hope this is helpful to those thinking of using Multibridge Extreme with Final Cut Pro.
    Chris Paul
    POV
    Chris Paul replied 20 years, 8 months ago 3 Members · 8 Replies
  • 8 Replies
  • Drazen Stader
    January 23, 2006 at 9:01 pm
    Chris hy,
    First of all, thanks for the great post you’ve. I am using an apple g5 2,7 ghz, 4gb ram machine and I was thinking about buying the ME (Of course when they release pci-e to pci-x adapter).
    I was wondering if you have tested the ME as standalone converter. What do I mean by that? Well let me put this way. I owe a sony-hdv deck, I am just finishing a feature documentary and I would love to have the finished product on a digi beta, or some other high end professional format (hopefully hd-cam). What I have is access to other post production facilities including decks and similar.
    I was thinking about dumping the whole film back to hdv (using firewire to sony deck), than take the sony hdv deck, use the new ME (using it as hdv – hdsdi or sdi signal converter) and hook it to a digi beta (completely avoiding any computer capturing or anything else).
    Does the new ME perform this type of stuff, or am I only dreaming? You see I would like to use it for something similar as the convergent box (they are advertising full power on the cow), and of course not only that. I would love to use the ME also for hdv component output capturing (using the 4:2:2 color, 8bit uncompressed, space and comopnent hd outputs).
    Any thoughts would be more than welcome.
    Drazen
  • Chris Paul
    January 23, 2006 at 10:23 pm
    Drazen-
    The ME does work as a stand alone when not connected to the PCIe bus. It does not convert directly from HDV to SDI but it will take the component analog outputs from the HDV deck and convert it to SDI for Digi-Beta or HDcam. You would still need a computer to configure the ME but the signal would go directly through the ME, bypassing the computer. Once the ME is configured it can run without any computer connection at all. The only thing I’m not sure about is whether the ME can down convert HDV to SD SDI in a stand alone configuration but your deck can do this part in any case. Perhaps this could be a 2 stage product for you- stand alone converter now, full interface later. My only concern would be the quality loss from all of the conversions ie: HDV>edit>HDV>Component Analog>SDI>final format.
    As far as using the ME for HDV component output capturing, I do that now. If you wanted to do so with the ME you would need to either wait until the PCI interface is released or buy the basic Decklink HD card- I think it it $295.
    [drazen] “I was wondering if you have tested the ME as standalone converter. What do I mean by that? Well let me put this way. I owe a sony-hdv deck, I am just finishing a feature documentary and I would love to have the finished product on a digi beta, or some other high end professional format (hopefully hd-cam). What I have is access to other post production facilities including decks and similar.
    Drazen
    Chris Paul
    POV
  • Drazen Stader
    January 23, 2006 at 11:04 pm
    Hy,
    I’ve just read your mail and have a couple of questions concerning it.
    1)Once the ME is configured it can run without any computer connection at all.
    Does this mean? Hook up the ME to my computer, set the proper configuration for the task that I need. Unplug the ME, and my hdv sony deck, go to the other studio, hook sony hdv > ME > digibeta and push play – record. Would this work in real life if the configuration of the ME is set properely.
    2) The only thing I’m not sure about is whether the ME can down convert HDV to SD SDI in a stand alone configuration but your deck can do this part in any case.e
    Do you have in mind the sony hdv deck downconverting from hdv to sd (that i find in the menu of the deck) this way we help the process by the decks innerconversion to sd
    3) Perhaps this could be a 2 stage product for you- stand alone converter now, full interface later. My only concern would be the quality loss from all of the conversions ie: HDV>edit>HDV>Component Analog>SDI>final format.
    I guess that also for that type os usage, I would need the basic decklink hd card, because as said before, first I have to configure the ME. Or maybe not true?
    4) loss from all of the conversions ie: HDV>edit>HDV>Component Analog>SDI>final format
    Has anyone tested this stuff out there? Generation loss quality? I have to say, that I have no intention of manipulationg the hdv picture. I had in mind just pure off line cutting for hdv material, maybe putting subtitles on top of it, and only when recaptured in high end medium (hd-sdi, or simply sdi), doing changes in terms of picture manipulation.
    5)As far as using the ME for HDV component output capturing, I do that now.
    How happy are you with the results? Have you ever compared it to simple firewire capturing, maybe playing with some greescreens on both materials, just to see how well they respond in different cases.
    6) If you wanted to do so with the ME you would need to either wait until the PCI interface is released or buy the basic Decklink HD card- I think it it $295.
    If I understand correctly, the purpose of the decklink hd card would be sdi in/out, which would allow me a migration to ME, and in that way would allow me to use it as a converter and nothing else. For all other goodies it would mean, waiting fot the pci-e interface to appear which could and probably will take a couple of months)
    A big thanks for the input
    Best regards
    Drazen
  • Steve Wargo
    January 24, 2006 at 6:27 am
    Miranda makes a device to do what you’re asking. It converts the HDV signal to HD-SDI
    Steve Wargo
    Tempe, Arizona
    It’s a dry heat!
  • Drazen Stader
    January 24, 2006 at 8:42 am
    Steve,
    Yes I know that Miranda and Convergent design both do what I need, but I was wondering if ME is capable of doing the same, this way I could have a stand alone converter and a video card all in one, and possibly save some money, and avoid the need of buying both.
    Drazen
  • Chris Paul
    January 24, 2006 at 5:06 pm
    [drazen] “Hy,
    Does this mean? Hook up the ME to my computer, set the proper configuration for the task that I need. Unplug the ME, and my hdv sony deck, go to the other studio, hook sony hdv > ME > digibeta and push play – record. Would this work in real life if the configuration of the ME is set properly.
    Once the ME is unplugged from it’s power supply it might be possible to lose the settings. I was referring to using it in a rack with other equipment as a stand alone converter. If you wish to move it to another studio you might need to have a computer with the Multibridge control software available in case in changed. I’m not saying that it would… but better safe than sorry.
    Yes.
    You do not need the Decklink card to configure the ME, only the Multibridge control software and a computer with a USB cable.
    My customers have been very happy so far but this has been from a subjective evaluation, not an engineering one. Unless you final product is going to PBS or German TV you will probably be OK. I would suggest talking with the end customer just to be sure.
    Firewire direct is a bit cleaner for simple editing, although my clients prefer the analog capture- they say it looks more “film like” and “Natural”- never mind the contradiction! If you are doing a lot color correction or other effects, you might consider offlining in HDV or HD100 and then recapturing and finishing in uncompressed 10 bit HD no matter what the final output is.
    6) If you wanted to do so with the ME you would need to either wait until the PCI interface is released or buy the basic Decklink HD card- I think it $295.
    If you had the Decklink HD card you could use it to capture through the ME- the ME would convert any analog sources to SDI that would then go through the Decklink card to your hard drives. This is how people with the standard Multibridge work now. You could start working immediately instead of waiting for the PCI interface or buying a PCIe computer.
    Best of luck!
    Chris Paul
    POV
  • Drazen Stader
    January 24, 2006 at 6:29 pm
    Chris,
    First of all thank you for your extremely resourcefull answers, many things have been clarified to me with your last post.
    I have only one question left concerning your last answer.
    Would the same principe apply to hd-sdi sources?
    Thanks a bunch
    Drazen
  • Chris Paul
    January 25, 2006 at 4:02 pm
    [drazen] “If you had the Decklink HD card you could use it to capture through the ME- the ME would convert any analog sources to SDI that would then go through the Decklink card to your hard drives. This is how people with the standard Multibridge work now. You could start working immediately instead of waiting for the PCI interface or buying a PCIe computer.
    Would the same principe apply to hd-sdi sources? “
    Yes. The ME will pass HD-SDI to the Decklink card without conversion if you wish while giving you the option of simultaniously viewing it on a standard definition monitor. This means that you can accurately judge color and motion without haveing to buy a high def monitor right away. You can also use it to make standard definition dubs without having to render- client approval VHS, for example.
    Chris Paul
    POV
