Multibridge Extreme – Distorted audio on embedded HD-SDI Audio
We just received a new Multibridge Extreme for use with FCP. Workstation is a Mac Pro with OSX 10.4. When attempting to monitor HD w/embedded audio via SDI on a Panasonic BT-LH2600W, the audio is distorted, or better perhaps garbled… not unlike a stereo phasing problem, but it is not exactly that either. The audio does not sound like, or appear to be overmodulated (built in audio metering on the monitor shows normal peaking as well – approx. -12dB). When I switch to SD downconversion or don’t output any video, the SDI embedded audio clears up and sounds just fine. I have tried various combinations, output formats and settings on the DeckLink control panel, but the bottom line is that any time I send any type of HD over SDI, the SDI embedded audio becomes distorted/garbled. I have downloaded and installed the latest Blackmagic drivers (DeskLink 5.7.1). Any thoughts? thanks
