Activity Forums Blackmagic Design MULTIBRIDGE extreme crash
  • MULTIBRIDGE extreme crash
    Posted by Oscarchan on July 15, 2006 at 6:58 pm
    G5 quad 2.5Ghz
    4.5GB RAM
    MULTIBRIDGE EXTREME
    FCP 5
    Playing sequence in FCP when I hear a snap and the computer freezes with dreaded spinning disc.
    check all peripherals then realise the multibridge is not on. It’s off, though it’s still plugged in. I shut everything down.
    Check the fuse- it’s fine. PLug it back in- and the LED on the front of multibridge flashes very briefly before going out again. Fan doesn’t start either. It seems dead. FCP doesn’t recognise it either when relaunched.
    I heard BMD products were well solid.
    Is it dead?
    Kristian Lam replied 20 years, 1 month ago 2 Members · 1 Reply
  • Kristian Lam
    July 17, 2006 at 1:41 am
    If you leave the power supply connected to the mains and to the Multibridge Extreme, does it still warm up?
    Kindly contact us at support[at]blackmagic-design.com and we’ll sort this one out for you.
