Activity › Forums › Blackmagic Design › Multibridge Extreme compatible with Decklink HD?
  • Multibridge Extreme compatible with Decklink HD?
    Posted by Matthew Beall on January 9, 2006 at 9:54 pm
    I’ve waited (or, got busy with other projects) to get a Multibridge+HDLink, and now I see the Multibridge extreme is out.. Is it compatible with my regular old DecklinkHD card? Can it do simultaneous HD and SD display (SD for video assist capture)? Can I preview my HD from my decklink through the Multibridge Extreme onto a Dell 24″ using the DVI (in other words, not have to get the HDLink)? Compatible with combustion and vegas?
    I will not be doing any 2K work any time soon, just plain-jane 720p and 1080i (and standard definition)..
    I plan to use it with a Panasonic Varicam via SDI and a Sony Z1 HDV using the analog component outputs..
    Answer fast! I plan to order in the next day or two!
    -Matthew
    Matthew Beall replied 20 years, 8 months ago 1 Member · 0 Replies
  • 0 Replies
