Activity Forums Blackmagic Design Multibridge Extreme as converter problem
  • Multibridge Extreme as converter problem
    Posted by Andrew Huebscher on March 12, 2007 at 8:24 am
    I’m using a Multibridge Extreme as a standalone converter. It is connected to a Dual 2.5GHz PCI-X G5 which itself has a standard Decklink HD card. The MB is only connected via USB. I am using it as a means of converting an HD-SDI signal from the HD card to an analog component out for my PVM-14L5. The 14L5 has an autodetect, and has displayed HD on it’s own before using other cards/cameras (i.e. Matrox Axio and a Panasonic HVX200), but I cannot get it to display any HD signal, only SD. I’ve tripled checked all connections… it stays in 480/60i or 575/50i. On the HD card in the G5, Video Desktop is DISABLED, as are any Up/Down Convert options. I’ve gone through every format in FCP’s setups to no avail.
    Thanks in advance,
    Andrew Huebscher
    Los Angeles, CA
    Andrew Huebscher replied 19 years, 6 months ago 1 Member · 0 Replies
  • 0 Replies
