Activity Forums Blackmagic Design Multibridge extreme and dell 24″ DVI
  • Multibridge extreme and dell 24″ DVI
    Posted by Pelle Ferner on December 2, 2006 at 11:18 am
    Hello.
    I just bought me an Dell 24″ screen and when connected to the mutibridge exteme dvi connection it wiev the 1080i picture from PremierePro2.0 correct but the output from aftereffect 7.0 to the Dell screen is very much too saturated and too high i contrast, but the analog SD signal is correct. Do annyone have hade this problem or know what could be wrong?
    Best regards / Pelle Ferner
    Pelle Ferner replied 19 years, 9 months ago 3 Members · 5 Replies
  • Miles Blow
    December 4, 2006 at 11:14 am
    Hi Yeah…. we noticed that aswell, we have a multibridge extreme with the dell 24 aswell. I think it has something to do with ram preview….cause when we look at footage in premiere pro2 that has a filter on it and needs to be rendered it has the same over saturated look. Let us know if you find a way of fixing it!
  • Pelle Ferner
    December 5, 2006 at 9:07 am
    I just wants to know if this is a Known issue or if I could fix it some how.
    System Spec.
    Tyan S2895
    2x Opteron 275 dualcore
    3 gb ram
    ATI x1900 xt 512mb
    Multibridge Extreme
    4x 250gb SATA2 raid
    Premiere pro 2.0 AfterEffects pro 7.0
    Dell 24″ Ultrasharp 1920 x 1200
    Best Regards!
    Pelle Ferner / Ruta Ett DVD AB SWEDEN
  • Kristian Lam
    December 5, 2006 at 10:45 pm
    This is not a known issue but we’ll check this out here to see what’s going on. What version of drivers do you have installed?
    regards
    Kristian Lam
    Blackmagic Design
  • Pelle Ferner
    December 6, 2006 at 9:43 am
    Hello.
    First of all, thanks for looking in to this problem I and some others have.
    I have updated to the latest driver (5.8) and the problem is still there. Both in Premiere (unrendered files) and Aftereffects (all files.)
    Best regards
    Pelle Ferner
  • Pelle Ferner
    December 6, 2006 at 10:57 am
    Hello again.
    I have now also tried to connect the MB with the YUV output to the component input to both my 42″ HD Plasma and tho the Dell monitor and the YUV is diplaying the correct picture in both HD and SD exactly as the analog Pal output is. So it
