Activity Forums Blackmagic Design Multibridge Extreme analog output DVCPRO HD video to SD monitor
  • Multibridge Extreme analog output DVCPRO HD video to SD monitor
    Posted by Rafal Szermanowicz – grupa #13 on May 14, 2006 at 10:43 am
    When I`m editing DVCPRO HD video I have only “single frame” output to my SD monitor ( connected via analog output ). Is it normal ?
    I tried to change output settings of MBE (HD to SD) but still i can see only one frame.
    Also I have one more question. What are bennefits if I add to my system DeckLink HD Pro PCIe ? More RT effects ? Or maybe only MB Extreme is enough ?
    PowerMac G5 Quad, 4.5GB RAM, GeForce 6600, Final Cut Studio
    BlackMagic Multibridge Extreme + 2.5TB ( 5 x 500GB ) TEMPO SATA E4P + FUSION 500P
    http://www.grupa13.com
  • Chris Borjis
    May 15, 2006 at 4:54 pm
    It sounds like the preview setting in final cut is not quite right.
    Try another setting.
  • Kristian Lam
    May 16, 2006 at 4:31 am
    Hi Rafal,
    What size and framerate is your DVCPRO HD timeline?
    [Rafal Szermanowicz – Grupa #13] “What are bennefits if I add to my system DeckLink HD Pro PCIe ? More RT effects ?”
    You can only run one card per system. Adding an additional card will not give you extra RT effects.
    regards
    Kristian Lam
    Blackmagic Design
  • Rafal Szermanowicz – grupa #13
    May 16, 2006 at 6:25 am
    I have used easy setup DVCPRO HD. My timeline is 1440×1080 25fps.
    I captured from Sony HDW 2000 but I didn`t have enough space so I decided to downconvert to DVCPRO.
    In FCP window I have smooth, 25fps playback but on my video monitor (composite) I see only single frames, or I have playback when I`m scrubbing but when I play from timeline I see only first frame and the last one.
    Rafal Szermanowicz
  • Kristian Lam
    May 16, 2006 at 6:45 am
    Hi Rafal,
    In this case, make sure you’re using the easy setup “Blackmagic HDTV 1080i50 – DVCPRO HD”.
    Create a new sequence and drop your clips into that sequence. Check your View > Video Playback settings and ensure that it is set to “Blackmagic HDTV 1080i 25Hz – 8 bit (1920 x 1080)”
    Next, go into the DeckLink Preferences and turn on down conversion.
    regards
    Kristian Lam
    Blackmagic Design
    May 16, 2006 at 8:41 am
    Thanks a lot Kristian.
    Now everything works great. I had easy setup “DVCPRO HD” not “Blackmagic HDTV 1080i50 – DVCPRO HD”
    Regards.
    Rafal Szermanowicz
