Activity Forums Blackmagic Design Multibridge Eclipse – SDI Output Problem
  • Multibridge Eclipse – SDI Output Problem
    Posted by Oli Trenouth on March 13, 2008 at 11:28 am
    Hi everyone,
    Has anyone else experienced this problem with the Eclipse?
    When I leave our MB powered for a few days continuously (say, over a weekend), I often find the SD-SDI output stops working. The other outputs continue to work fine – and since most of our monitoring is done via HDMI or component, this problem usually goes unnoticed until we output to tape. I’ve also had instances of this glitch affecting the SDI input – but not as frequently.
    I’ve tried all the obvious stuff:
    – Toggling the video output in FCP
    – Toggling input and output modes in the Decklink Preferences
    – Switching between HD and SD (Most of our projects are SD)
    I’ve also found that rebooting the Mac doesn’t always fix the problem. I usually have to power down both the Mac and the MB. (Is there a way to restart the MB without restarting the Mac?)
    I know the obvious fix for this is to powerdown at the end of each day – but it isn’t always practical to do this (Overnight encoding, out of hours use, etc)
    Has anyone else experienced this?
    Kind regards,
    Oli Trenouth.
    Our setup:
    Quad G5 PowerPC / 2.5GHz / 4Gb
    XServe RAID / 6Tb
    FCS v2
    MB Eclipse
    SD-SDI Output to/Input from Digibeta & DVCPro/DVCAM
    Monitoring via HDMI & Component
    Oliver Trenouth
    Media Developer / Editor
    National Media Museum, UK
    Margus Voll replied 18 years, 5 months ago 3 Members · 3 Replies
  • Kristian Lam
    March 14, 2008 at 9:23 am
    Hi Oli,
    Which version of drivers do you have on?
    regards
    Kristian Lam
    Blackmagic Design
  • Oli Trenouth
    March 14, 2008 at 10:25 am
    I’ve experienced this problem with 6.6.1 and 6.6.2. (More so with 6.6.2)
    Just updated to 6.6.4, so will see what happens on Monday.
    Oli.
    Oliver Trenouth
  • Margus Voll
    March 16, 2008 at 8:16 am
    Hi.
    Where do you keep your unit.
    Maybe it heats up too much etc. conditions change over weekend.
    Margus
    https://iconstudios.eu
