Activity Forums Blackmagic Design Multibridge and premiere cs3 on vista
  • Multibridge and premiere cs3 on vista
    Posted by Pelle Ferner on October 9, 2007 at 4:22 pm
    Hello.
    Just wanna see if anyone els experience the same problems as I do. I have just updated my system to a Vista 32bit and the adobe collection to cs3. And first of all the decklink (version6.5)control have trouble to start because a mcf71.dll file where missing. After trying to reinstall a couple of time both my system, my adobe collection and the decklink drivers with no better luck. I simply copy a mcf71.dll file from my old xp installation into the decklink program folder. Then it all starts to work. Fine???
    Now my only problem is that in Premiere, When I play a clip on the timeline it outputs correct on the monitors in both HD and SD and the audio/video synk is perfekt without dropping frames. But in the program and in the computur previuewindow it
    Deleted User replied 18 years, 11 months ago 2 Members · 5 Replies
  • Deleted User
    October 10, 2007 at 2:37 pm
    Hello Pelle,
    I was having the same problem with the DLL errors with Multibridge Drivers 6.4 and 6.5 on Vista Ultimate 32 bit.
    I formatted my hard drive, then re-installed Windows Ultimate 32bit. I then updated all my drivers, then Installed Adobe Production Studio Premium cs3.
    I then turned off the “user access control” in Vista, I then shutdown my pc. Attatched and power up the Multibridge Extreme for about 60 secs. Then I powered on Vista, then run the 6.5 installer.
    I then re-booted after installing the drivers for Multibridge installer. I then went into the Decklink control panel form within the control panel of Vista, I then did not get the DLL error associated with that, I also checked Deck control and I then did not get the DLL error as well.
    I video taped, the install process as I been trying to get these DLL problems fixed with Black magic design tech support in the US. I can send you the video for you to follow?
    What are your system specs?
    I am using
    Intel Quadcore 6600 2.4ghz
    2x2gb of OCZ ddr2 ram
    Asus Motherboard P5N32-E SLI Plus
    Graphics XFX Nvidia 8800gtx 768mb ddr3
    Adobe production Studio Premium CS3
    When you say abourt dropped frames on the timeline, what project preset are you using? What file format and bit rate and depth?
    Leo Baker
    Post Production
    Sync Films
    United Kingdom
    http://www.syncfilms.com
  • Pelle Ferner
    October 12, 2007 at 4:08 pm
    Hello Leo.
    Nice to here that I
  • Deleted User
    October 12, 2007 at 4:59 pm
    Hello Pelle,
    Yes, I am getting correct output of 1080i and 720p to my Dell Ultrasharp 24″ monitor via the DVI out of the Multibridge Extreme while in After Effects cs3.
    When you get low res in the Premeire playback and choppy. What frame rates, and compression are you using?
    If I can get the audio problem fixed when in Mied a Player, I-Tubes, Bridge, then I will be okay.
    Can you send me anu screengrabs of the After Effects output with the over saturated dvi?
    Leo Baker
    Post Production
    Sync Films
    United Kingdom
  • Pelle Ferner
    October 12, 2007 at 5:16 pm
    Hello.
    That was very good to here that your previue is workin. Maybee there is hope for me to then.
    Are you working in HD?
    Is it possible for you to send me an email at info@rutaett.com so could I send you some pictures.
    🙂 Pelle
  • Deleted User
    October 12, 2007 at 5:29 pm
    Hello Pelle,
    Yes, HDV 720 and 1080i
    Leo Baker
    Post Production
    Sync Films
    United Kingdom
