Activity Forums Blackmagic Design Multibridge and Cineform
  • Multibridge and Cineform
    Posted by Scott Jensen on April 20, 2005 at 9:17 pm
    The Cineform website mentions “Aspect HD: with Blackmagic HD-SDI card support”.
    Does Aspect HD also include support with the Multibridge. What about support via the component input and not just the HD-DSI?
    i.e., will I be able to input HD-SDI or uncompressed component HD and get Aspect HD video out of the multibrige?
    Scott Jensen replied 21 years, 5 months ago 2 Members · 2 Replies
  • Luke Maslen
    April 21, 2005 at 5:16 am
    Hi Scott,
    All Multibridge models are designed to act as standalone convertor and you can also connect a Multibridge to your PC via a Decklink card such as the DeckLink HD. This provides the HD-SDI connection to Aspect HD, regardless of whether you are using the component connections of the Multibridge or not. Multibridge seamlessly converts between HD analog and HD-SDI and vice versa. So as far as Aspect HD is concerned, it is just working with HD-SDI.
    The new Multibridges with PCIe include a PCIe adapter card for your PC. As far as your PC is concerned, it will think that it is just working with a DeckLink card via HD-SDI and that fact that the Multibridge unit is external is of no consequence. In other words, Aspect HD should view the Multibridge with PCIe as if it were just any DeckLink card with HD-SDI.
    So yes, you should be able to use component HD analog and have Multibridge convert it to HD-SDI for use with Aspect HD as it will be just like using a DeckLink HD card.
    Regards,
    Luke Maslen
    Blackmagic Design
  • Scott Jensen
    April 22, 2005 at 8:02 pm
    Can the cable from the Multibridge plug directly into the pci express card slots on some of the new notebooks that have PCI express?
    The Decklink site mentions 4 lane PCI express slot is required for doing HD work with the multibridge. Is 4 lane another term for 4x PCI express? Will your 4 lane pci express card work in a motherboard with 8x PCI express slot(s)?
