Activity › Forums › Blackmagic Design › Multibridge 3DLut
  • Multibridge 3DLut
    Posted by Margus Voll on April 22, 2009 at 8:47 am
    Hi.
    I can see on my MB control panel output has 3D LUT’s.
    Is this similar to HDLink Pro.
    What i mean can i connect SDI or HDMI monitor to my multibridge and use
    Cinetal LUT tables as HDLink Pro can?
    It would be really great if it works as i hope.
    Margus
    https://iconstudios.eu
    Luke Maslen replied 17 years, 5 months ago 2 Members · 2 Replies
  • Margus Voll
    April 22, 2009 at 3:30 pm
    Generally my goal would be to hook up Flanders Scientific on SDI with Cinetal 3D LUT and if i can do it without HDLink then i’ll be happy.
    At the moment it seems that Multibridge can do it.
    If enyone can confirm it ?
    Margus
  • Luke Maslen
    April 23, 2009 at 2:29 am
    Hi Margus,
    Multibridge uses the same 3D LUT system as HDLink Pro. So if your Cinetal LUT tables work with the HDLink Pro, they should also work with Multibridge 🙂
    Multibridge applies the 3D LUT’s to all outputs whereas HDLink Pro and HDLink Optical Fiber provide the option to only apply the 3D LUT’s to your display or to apply it to the SDI loop-though output(s) as well. However my belief is that you only need the Multibridge for your intended workflow.
    Regards,
    Luke Maslen
    Blackmagic Design
