Activity › Forums › Avid Media Composer › Multi source project
  • Multi source project
    Posted by Shelly Hermetz on May 16, 2011 at 8:32 pm
    I’m about to start a projct on AVID MC5. My problem is that some of the fotage were taken on mini-dv tapes while other were taken on Panasonic HD Camera and are MTS files.
    How should I define the settings of this project??
    Shelly Hermetz replied 15 years, 4 months ago 3 Members · 3 Replies
  • Brendan Maghran
    May 17, 2011 at 12:02 am
    I’m not even familiar with MTS, I’ve never worked with it before, but in a situation with mixed resolutions go with an HD Project setting, and upconvert the SD material.
    “Where that light source is coming from?”
    “The same place as the music.”
  • Shane Ross
    May 17, 2011 at 12:36 am
    Depends. Is your final product SD or HD? Answer that, and you have your answer.
    Shane
  • Shelly Hermetz
    May 17, 2011 at 12:25 pm
    Well, my final result should be a DVD so I guess it is SD, since the DVD plays only SD media.
    If so, I should define the project as SD? are there any import settings I should use when importing the HD materials into it?
    Shelly
