Activity › Forums › Maxon Cinema 4D › multi shader problem
  • multi shader problem
    Posted by Gon Perdigao on November 12, 2010 at 12:02 pm
    Hi there i have a cloner with several planes and i want to use a different texture (that in this case is a video) in each plane, so i use a shader effector.
    I selected the index ratio in the shader effector.
    But i have two problems, one is that the footage that in putting in each shader, when i render is different of the one i selected, and the other problem is that in just some planes the texture is different, what i’m i doing wrong?
    Thanks a lot!
    Gon Perdigao replied 15 years, 10 months ago 1 Member · 0 Replies
  • 0 Replies
