Activity › Forums › Maxon Cinema 4D › Multi Shader on NON Clone Object
Posted by Joe Bodego on June 19, 2016 at 7:06 amHello, i know how to do a multi shader on cloned objects, is there a way to do Multi shader on non clone objects. I have some spline text separated into individual letters and would like to shade the type without doing a color for each letter. Your help would be greatly appreciated
Joe Bodego replied 10 years, 3 months ago 3 Members · 5 Replies -
Adam Trachtenberg
June 19, 2016 at 3:36 pmYou can put your extruded text inside a mograph fracture object (set to explode and connect). Put the multishader material on the fracture object and then assign an effector — like the shader or step effector — in color mode only to the fracture object. You’ll probably have to play with the effector’s Min/Max settings to get the distribution you want.
Brian Jones
June 19, 2016 at 3:50 pmYou can use a Cloner (not the best way probably but just saying…) by putting all the objects into the cloner (Clones set to Iterate – which is the default) and setting the cloner Mode to Linear (or using a spline (cloner in Object mode or Linear with Spline Effector)) to arrange the text out) – spacing is the problem here (the cloner will control the spacing of the letters and it’s kind of a pain (but possible) to get the letters exactly where you want them) but the MultiShader set to Index Ratio works like you’d expect.
Putting all the letters in a Fracture object is better for spacing (they stay exactly where you put them) but Index Ratio to control the colours can be a bit of a problem. It works well if you use a Step Effector (with Color Mode set to On) with the Fracture, then use the MultiShader set to Color Brightness. -
Joe Bodego
June 19, 2016 at 11:14 pmYou lost me here ” like the shader or step effector — in color mode only to the fracture object” Please explain
Joe Bodego
June 19, 2016 at 11:26 pmAfter playing around, i figured it out, thanks for pointing me in the right direction, much appreciated
