Activity › Forums › Apple Final Cut Pro Legacy › Multi-sequence multiclips?
Posted by Robin on August 10, 2005 at 10:27 amHi all
I want to create a multiclip sequence with the individual clips being sequences rather than single clips.
Is there any way to do this without going the route of rendering out sequences and re-importing them as clips?
Thanks.
Tom Wolsky replied 21 years, 1 month ago 4 Members · 6 Replies -
Jerry Hofmann
August 10, 2005 at 10:59 amI don’t quite understand what you are trying to do… if you’d explain it better? or maybe even give the reason for this?
Jerry
Apple Certified Trainer
Author: “Jerry Hofmann on Final Cut Pro 4” Click here
Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D
Tom Wolsky
August 10, 2005 at 11:10 amSequences cannot be incorporated into multiclips. You have to export and reimport as a stand-alone to make it part of the multiclip.
Craig Seeman
August 10, 2005 at 3:09 pmFor those reading this thread and wondering why using sequence would be a useful thing in creating mutliclips:
1) staggered reel changes on long multicam shoots.
2) The stop/start in which time code is continuous but one wants to split the clip to resync.Yes, I know there are work arounds but it would be much simpler to insert a slug for the missing video and keep the camera angle continuous.
Craig Seeman
August 10, 2005 at 3:13 pmSplit the clip where it brakes and place it as another angle (makes it confusing for client watching and clutters screen).
Create sequence and export/reimport (but lose original time code).
Only do multiclip until a “break point” and then create another multiclip (breaks the fluidity of screening/editing).
Tom Wolsky
August 10, 2005 at 3:19 pmI agree with you Craig. It’s actually something I think Lisa Brennais and I talked about to some Apple folks back at NAB.
