Activity Forums VEGAS Pro Multi-select import order ?
  • Multi-select import order ?
    Posted by Walker Angell on September 20, 2010 at 7:19 pm
    Trying to do a quick slideshow. Image filenames are numbered (001.jpg, 002.jpg, 003.png, etc). When I select them and drag them to the timeline Vegas (Pro 9) seems to be doing a random order instead of filename order. And it’s different each time. Haven’t been able to find a setting for this anywhere. Options/Edit has settings for xition time, image time, etc, but nothing for import ordering.
    IIRC, all the older versions all defaulted to filename order.
    Is there something I’m missing? Bug??
    Walker Angell replied 15 years, 11 months ago 2 Members · 2 Replies
  • Edward Troxel
    September 20, 2010 at 7:59 pm
    The one that you drag will be FIRST. The rest will be in numerical order. So make sure you drag the first one. What’s WINDOW’s convention of doing things.
    Edward Troxel
    JETDV Scripts
  • Walker Angell
    September 20, 2010 at 8:21 pm
    That was it! Thank YOU! As many times as I used to do multi-selects like that I can’t believe I never ran in to that before. Must have accidentally grabbed the first one instead of just somewhere in the middle of the select like I was doing today.
