Activity Forums Adobe After Effects Multi-Screen
  • Multi-Screen
    Posted by Eric Santiago on September 19, 2023 at 9:34 pm
    I can’t seem to find anything that can do this.
    I want to create a multi-screen project but in a dynamic form.
    If you look at this video (URL on actual frame)
    https://youtu.be/oBxPQz_WmCA?t=23
    and you see the multiple screens, I would like one where if you transform one screen in any direction it would affect all the other screens as well.
    I don’t mind if cropping is involved but scape/position should also be involved.
    Seems like a pipe dream but if anyone can direct me to the right template/tutorial.
    Much appreciated!
    Eric Santiago replied 2 years, 12 months ago 2 Members · 3 Replies
  • Eric Santiago
    September 19, 2023 at 10:09 pm
    So far I found this one 🙂
    https://aescripts.com/flex/
  • Graham Quince
    September 20, 2023 at 8:36 am
    Flex looks great and that’s probably the easiest approach, but if I was trying to do this on no budget, I probably do the following:
    • Create a set of precomps, one for each layout
    • Animate the layers to appear in each.
    • Set the precomps up as Essential Graphics so that I could swap the layers out from the main comp
    • Then all that’s needed is to add them in the order I want.
    (Having said all that, Flex is only $25)
  • Eric Santiago
    September 22, 2023 at 2:31 am
    Agreed with your workflow and yes I have done that with other projects.
    I’ve been testing the Flex demo and so far I love it.
    However, I have to say the steps you suggested would have been just as rewarding but the trip would have been long.
    I did something similar using Maya with vertex on polygons and then exported the outlines and matched it in AE. It was more of a fluid result but the process of converting to layers in AE was way too long to deal with.
    Still a fun experience but not as easy as a plugin.
    Flex has its shortcomings but that could just be lack of experience with it.
