Activity Forums Apple Final Cut Pro Legacy multi purpose monitor for fcp on mbp
  • multi purpose monitor for fcp on mbp
    Posted by Corey Maynard on December 3, 2009 at 5:44 am
    Hi Guys … about to upgrade my humble imac to mac book pro 17″
    I want to buy a 32″ external monitor along with it which i’d also like to use as a Tv and dvd monitor in one.
    My budget is about $1000au, any suggestions appreciated
    Cheers,
    Corey
    Jerry Hofmann replied 16 years, 9 months ago 2 Members · 1 Reply
  • Jerry Hofmann
    December 3, 2009 at 11:56 am
    You’re going to need more than just a TV set to do this… you need a way to view external video from a laptop, so will need hardware to sit between the TV and your mac. AJA’s Io Express, or a Matrox MXO2 series box.
    The 17″ has that expresscard slot so you’re good to go there with the box you’ll need. I don’t think the MXO can do this with the mini display port.
    That said, any TV will work with the inclusion of the box mentioned above. The more you spend, the more you get pretty much. If you can live with a 720 display instead of an 1080, you’ll save about 250 US… I do like most anything Panasonic or Samsung makes for the price…
    Jerry
    Apple Certified Trainer, Producer, Writer, Director Editor, Gun for Hire and other things.
    8-Core 3.0 Intel Mac Pro, Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D, AJA Io HD, 17″ MBP, Matrox MXO2 with MAX Cinema Displays
