Activity › Forums › Adobe After Effects › multi-point gradient along a mask?
  • multi-point gradient along a mask?
    Posted by Jimmy Brunger on June 11, 2007 at 10:37 am
    Hi all,
    I’m trying to apply a bit of a gradient to a 3D stroke layer that is wrapping around an object, to give a little bit of fake lighting/depth to the stroke…I ideally want to be able to get 3 or more points along the stroked mask from black to white, but ramp and 4-colour gradient are not working, because I need the gradiations to follow the mask.
    Is there a simple solution to this I’m just not seeing?
    Thanks.
    *Production Studio Premium / *Combustion 3
    Win XP Pro SP2 / Intel P4 3GHz / 2GB RAM / GeForce FX5200 / DeckLink Pro / Sony BVM-20G1E / DVS SDI Clipstation / 110GB boot/80GB media/600GB RAID-0
    Jimmy Brunger replied 19 years, 3 months ago 15,596 Members · 1 Reply
  • Jimmy Brunger
    June 13, 2007 at 10:18 am
    Thanks Dave, I was thinking of trying CC Cylinder, but I’ve a feeling I’m not going to be able to do what I want with it and I may have to pass it onto our Lightwave guy. Here’s what I need to do – if you have any suggestions that’d be great! :-
    I’ve got a shot of someone sat in an armchair and the shot is slowly tracking around the subject and pulling out at the same time. The client wants some text to come out from behind the chair and flow around infront of the subject, like a kind of 3D ribbon made of text (yep that old chestnut) I was trying it with 3D stroke for a test anyway, but I’d have to find a way of replacing that with text anyhow..
    I don’t think the shot will need tracking, as the text isn’t actually attached to anything, so can probably cheat it’s position. I’d usually pass off the 3D to someone else, but I just wanted to see if I could do it (fairly quickly and so it’s editble) in AE? I’ve seen various tutes on here for ribbon text, but nothing that really suits and moving object..I thought maybe expressions, but that just looks like a world of pain!
    Any ideas guys?
    Cheers.
