Activity Forums Maxon Cinema 4D Multi-pass issue
  • Multi-pass issue
    Posted by Jason Stirret on July 8, 2012 at 5:38 am
    When I set up my render using multi-pass the image comes out changed. If i render without multi-pass it looks as it should (i.e. like I want it to). The picture w/ multi-pass is greyed down and dull. Don’t know how to resolve this. Even if when all the multi components off except for the object buffers, still looks terrible.
    I want to use multi-pass for Photoshop post editing but when I’m using the multi-pass it makes the image different. Any suggestions?
    Jason Stirret replied 14 years, 1 month ago 2 Members · 2 Replies
  • Adam Trachtenberg
    July 9, 2012 at 5:01 pm
    Hard to say for sure without seeing your settings, but it sounds like you may have a color profile or gamma issue. Are you exporting linear gamma?
  • Jason Stirret
    July 10, 2012 at 3:20 pm
    I believe you are right, I suspect I’m running into some compound gamma. Going to tweek a few things and see what happens.
