Activity Forums Adobe Illustrator multi page PDF to Illustrator
  • multi page PDF to Illustrator
    Posted by Anders Hattne on September 26, 2011 at 8:05 am
    Gooday,
    I’ve got to use pages from a PDF in an After Effects project, but in AE I can only import Illustrator files. So I have to convert them from the PDF to .ai
    Question is if there’s a quicker way of doing this, since it’s a 70 page pdf..?
    thanks
    http://www.ardillamedia.com
    Anders Hattne replied 14 years, 7 months ago 3 Members · 3 Replies
  • Vincent Rosati
    September 27, 2011 at 6:35 am
    You’re trying to reverse a typical workflow.
    Maybe you could Acrobat: Document/Extract Pages as Separate Files. Then if you’re on a Mac you could likely set up a job with Automator to batch all of the files to AI.
    I haven’t done this for PDF to AI, but I have done batch DOC to PDF.
    Vince
    *Please remember to Rate our replies or check Solution if solved. If you get a good idea from the post, consider clicking the Kudos option.
  • Les Nemeth
    September 27, 2011 at 8:21 pm
    So what is the problem? You can open PDF files in AI just fine.
    You can also rename a .PDF file to .AI and it “becomes” and AI file and opens just fine in AI. Select the page to open, and save it as AI.
    Is that hard?
  • Anders Hattne
    February 1, 2012 at 6:27 pm
    Whoops!! Forgot to get back to this thread.
    No it’s not hard. It’s just time consuming. Had a lot to do other than opening the PDF file at the right page and resave it as an AI.
    Done by now though..
