Activity Forums Adobe Premiere Pro Multi-monitor issue
  • Multi-monitor issue
    Posted by Marcelo Lewin on August 3, 2005 at 11:03 pm
    Weird thing. I just got a new Dell M70 laptop and I’m using my second monitor and I get the full screen of my sequence in that monitor (as if I had a 3rd monitor displaying the actual output). So I can’t move anything there because of that. What can be the problem? Are there settings in PPro somewhere that I can change?
    Marcelo Lewin
    marcelo@thedailyfarce.com
    https://www.thedailyfarce.com/
    Marcelo Lewin replied 21 years ago 2 Members · 6 Replies
  • Steven L. gotz
    August 3, 2005 at 11:59 pm
    The settings are in the drivers for the display. You need to set it up to extend your windows desktop to that monitor. Right click on the Windows wallpaper and select properties, then Settings.
    Steven
    Adobe Premiere Pro 1.5.1 / After Effects 6.5 Pro https://www.stevengotz.com
    Learning Adobe Premiere Pro 1.5 https://www.lynda.com
    Contributing Writer, PeachPit Press, Visual QuickPro Guide, Premiere Pro 1.5
  • Marcelo Lewin
    August 4, 2005 at 1:55 pm
    Hi Steve,
    Yeah…that part I got…That’s no problem. I’ve been using Premier with 2 monitors for a while, what is happening since I got my new laptop is that my second monitor is showing the full screen preview of the sequence (the entire screen is the preview) and my laptop monitor is showing me Premiere Pro (software). I’m not sure why that is happening. Any other ideas?
    Marcelo Lewin
  • Steven L. gotz
    August 4, 2005 at 4:21 pm
    I know how to make it do that on purpose for a few video drivers. Can you tell who makes the video card? Or in your case, the chips? nVidea? Radeon?
    Is there a place to uncheck “Full Screen Video”?
    Steven
  • Marcelo Lewin
    August 4, 2005 at 4:45 pm
    It’s the NVidia Quadro FX Go1400
    Marcelo Lewin
  • Steven L. gotz
    August 4, 2005 at 10:10 pm
    If these menus apply, these are the instructions to make it do that, so if you change the
  • Marcelo Lewin
    August 4, 2005 at 11:39 pm
    I had to change it to disable….thank you very much….that did it though.
    Thanks for you help!
    Cheers!
    Marcelo Lewin
