Activity Forums Apple Final Cut Pro Legacy multi-layer audio – inconsistent cutting out FCP
  • multi-layer audio – inconsistent cutting out FCP
    Posted by Tali Clarke on August 22, 2012 at 8:47 am
    Hello!
    I have a project with multiple audio layers – a documentary with a running v/o, music and occasionally ambient noise. When playing back in the timeline, if there is a moment where v/o, music and ambient are all present at once, sometimes it plays back all 3 and sometimes the music cuts out. There seems to be no consistency in this occurrence, as all music is on 1&2, v/o on 3&4 and ambient on 5&6, and it happens at different parts in the timeline (i.e. there is no pattern to them cutting out, such as all in the second half of the film)
    There is no red bar on my timeline indicating any further need for rendering.
    I have tried both Safe and Unlimited RT – no difference.
    I’m on FCP6
    Mac Book Pro with 4gb RAM
    Any thoughts or suggestions on this would be massively appreciated, cheers! Tali
    Joe Barta iv replied 13 years, 9 months ago 2 Members · 1 Reply
  • Joe Barta iv
    August 22, 2012 at 1:53 pm
    Sounds like FCP is trying to playback everything in real time, but doesn’t have all the resources it needs so it cuts back on some things, like the number of audio channels during playback.
    Go to the Sequence drop-down menu, select Render Only, then select Mix Down. You may have to do this many times, as you make changes to the audio it will need to be re-rendered for correct playback.
    Bars & Tone
    SALUTE!
