Multi frame size and frame rates project workflow.
Hi!
I’ve not edited for almost 4 years now, so bear with me <3
I’m working (or about to) on Avid 8.3.1, with 3 different footages.
Codec is always H.264 – MPEG-4 AVC (part 10). But then:
1 MPEG-2 files / 1920X1080 / 29.970030i UFF
A52 Audio (aka AC3) (a52) / Stereo / 48000 Hz / Bitrate 256 kb/s
2 QuickTime files / 1280X800 / 59.912976 progressive
MPEG AAC Audio (mp4a) / Stereo / 44100 Hz
3 MPEG-4 files / 1920X1080 / 50 progressive
PCM S16 BE (twos) / Stereo / 48000 Hz / Bits per sample: 16
I would first of all like to confirm I should AMA-link and then transcode (as opposed to importing). I’m assuming this is the way to go, since I’m working with camera footage and lengthy QT files (screen recordings), no graphics with alphas.
I’m also wondering if I should create 3 separate projects that match the frame rate of the video files, AMA-Link, transcode them and then copy the Bins containing the AMA-Links and transcoded files into a main project. Or should I AMA-Link and then transcode in one same project from scratch? An HD 1080p/29.97 one?
Now… which target video resolution do you recommend? What about audio format, sample rate and bit depth?
How do you recommend that I deal with the mixture of interlaced and progressive?
This is a short film which I intend to enter into film festivals an eventually make available online.
Thanks in advance!
Rosario
