Activity Forums Boris FX Multi-Frame Mode
  • Multi-Frame Mode
    Posted by Matt Mccoy on January 26, 2011 at 2:19 pm
    I am playing around with Graffiti 5.3.2.1500. One of the things I find confusing is making a change to my text, then having to go to the last keyframe and make it there. I have also been using copy/delete/paste keyframe.
    I know you can use hold parameters to make it stick, but I may want to animate it later. Chris Vadnais talks about Multi-frame mode, but I don’t see it in my tools window. Is there another way to do this?
    Matt Mccoy replied 15 years, 7 months ago 2 Members · 2 Replies
  • Peter Mcauley
    January 26, 2011 at 8:07 pm
    You can use “Constant” interpolation mode to eliminate the problem that you are having with setting the same values at the start and the end of the effect. To set a parameter to use Constant keyframing, click in the keyframe interpolation box and select Constant from the pop-up list.
    I hope this helps.
    Cheers,
    Peter.
  • Matt Mccoy
    January 27, 2011 at 1:01 am
    Thanks Peter,
    I had come across the constant keyframe before, but sometimes I forgot to change that if I go back and try to animate later. I guess multi-frame got dropped at some point-the book I have is quite old!
    thanks,
    Matt
