Activity Forums Storage & Archiving Multi Format Systems ??? – semi quick opt in and out…
  • Multi Format Systems ??? – semi quick opt in and out…
    Posted by Jake Hawkes on July 17, 2009 at 7:53 am
    Hello and thanks for the response in advanced!
    I would like to direct a network IT professional that is willing to help with the clients/switch/cabling/storage config to some information about Mac / Windows compatible shared storage at data rated at or near what Bob and Walter have achieved. The only thing I can find in the realm of my reality is:
    StoreNext
    https://www.quantum.com/AboutUs/Events/ibcinfo/Index.aspx#prod1
    Anyway, I do a tremendous amount of work in Premier and for it’s previous lack of stability it has proven to be a god send this past year…ok let the bashing begin.
    The real key for me is allowing clients ‘would be video editors’ in to the office and giving them plug and play access to my storage/assets. It seems like I can work with different CODECs which are all quite good to get my bandwidth requirements down. Oh and being able to pull stuff through the internet (not for real time editing or anything) would be cool too.
    Is this possible?
    THANKS AGAIN FOR NOT BASHING ME!
    You’ve Had Our Potatoes!
    Bob Zelin replied 17 years, 2 months ago 3 Members · 6 Replies
  • Chris Blair
    July 18, 2009 at 5:02 pm
    I could be wrong but I don’t think you need software like StoreNext to achieve this. If you’ve read Bob and Walter’s configurations in past posts, they’re just using native Apple file-sharing.
    There are others on this forum, including me, who are using plug and play hardware/software combos that will work with both PCs and Mac’s right out of the box. Our system is the Apace vStor, but there are others out there that do the same thing I believe. They’re built on Linux architecture and I’m pretty sure you can have a PC hooked to it running Premiere using .avi files in one room, and have a Final Cut workstation on a MAC using .mov files in another.
    That said, you need to give Bob and the others that do more engineering type work more info, like are you wanting to edit HD or SD, what codec or data rates will you primarily be using etc.
    Also…I’d be wary about the idea of having people come in and edit on my shared storage setup if they’re not at least familiar with some basic asset management guidelines…like where to setup render directories, where to store project files etc. If you don’t, you’ll have a mess on your hands since everybody’s brain works differently and people have a tendency to put files all over the place.
    Chris Blair
    Magnetic Image, Inc.
    Evansville, IN
    http://www.videomi.com
  • Jake Hawkes
    July 20, 2009 at 2:45 pm
    Thanks for the feedback.
    We work on DVCPro and PRO Res HD or lower bandwidth assets…the needs we have are covered by Bob’s system with some overhead but I am not sure if it is OS agnostic and if I can use a Windows server rather than a Mac…
    Sorry such lame questions but as I don’t have Mac systems it is a big concern given that all I see so far is people doing this sort of system on a Mac.
    The shared environmental variables you mentioned are pretty basic and those rules apply to people working on their local disk but it is good advice none the less.
  • Chris Blair
    July 20, 2009 at 8:15 pm
    I don’t think Bob and Walter’s configurations have been tested on PCs. They’ve been tested extensively on MACs and since PCs are going to use different file-sharing protocols, it’s anybody’s guess if it will work.
    You can get systems that work right out of the box for under $9,000 for PCs. Of course that doesn’t take into account a new high-end switch, possible new ethernet cards, backup, cabling etc. You might read down thru past posts to see who’s built a PC specific system and had success if spending $12-15k is more than your budget.
    Chris Blair
    Evansville, IN
  • Bob Zelin
    July 21, 2009 at 2:58 am
    I don’t know the answer to your question. I don’t know how to build a cheap PC based system, that has a PC server, PC clients, and a link agg switch (like a HP ProCurve) to do your job. As Chris said, you can buy a turnkey soltuion from a company like Apace or EditShare, but to do a “home made” solution like I described for PC’s – I just don’t know. I have not done it.
    Bob Zelin
  • Jake Hawkes
    July 21, 2009 at 4:13 am
    Bob,
    I really appreciate you weighing in! I am going to give it a shot PC prices being what they are and will get back to ya’ll.
  • Bob Zelin
    July 21, 2009 at 3:31 pm
    Hi Jake –
    just remember, you will need a managed ethernet switch, that can do LACP (link aggregation), support jumbo frames and flow control. Your cheapest bet is probably the HP ProCurve. You will need a multi port ethernet card. I would not put one penny into the disk drives (the expensive part of this project) until you got your switch setup and connected to your other PC’s. You can do basic lo res tests without any disk drive array. This way, you will save yourself the financial aggrivation if something goes wrong.
    Bob Zelin
