Activity Forums Apple Final Cut Pro Legacy Multi-Format question
  • Multi-Format question
    Posted by Tom Brooks on July 19, 2010 at 12:23 pm
    I’m shooting in Haiti next week and will need to combine several sources of footage when I get back. The sources will be:
    1080i59.94 Sony EX-1
    480i29.97 DV
    720p23.976 DVCProHD
    Can these all be dropped into a 720p59.94 DVCProHD timeline with good results? Any other solutions for combining? Thanks.
    – Tom
    Jerry Hofmann replied 16 years, 1 month ago 2 Members · 3 Replies
  • Jerry Hofmann
    July 19, 2010 at 1:18 pm
    What do you need to deliver in the end? HD? or a DVD or?
    Jerry
    Apple Certified Trainer, Producer, Writer, Director Editor, Gun for Hire and other things. I ski. My Blog: https://blogs.creativecow.net/Jerry-Hofmann
    8-Core 3.0 Intel Mac Pro, Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D, AJA Io HD, 17″ MBP, Matrox MXO2 with MAX Cinema Displays
  • Tom Brooks
    July 19, 2010 at 2:11 pm
    Deliverables will be DVD and web video. Blu-Ray might be a bonus, but not essential. It’s mostly for fundraising meetings and a web site. I’ve had mixed results using 720p60 for DVD, but if it’s a good way to handle the mixed frame rates, it might be worth it. For the web, I have no problem cutting the frame rate in half during compression.
  • Jerry Hofmann
    July 19, 2010 at 5:14 pm
    Is there a predominate format for the footage? like is most DV or? You might chose sequence settings for what you have to deliver, which is SD or lower… but if you want a Blu-Ray in the end, you’ll need at least a 720p sequence setting… I’d transcode what you end up using of the SD footage in the end through a hardware setup like a capture card or better yet through a terranex.
    Jerry
