Activity Forums Broadcasting MULTI-FORMAT MONITORS (cross-post, sorry)
  • MULTI-FORMAT MONITORS (cross-post, sorry)
    Posted by Jim Blokland on June 17, 2005 at 12:11 pm
    Hello all:
    Wondering if you can help me clarify — what is the advantage to having a multi-format monitor (say, the PVM 20L5 vs. the PVM 204MU)? If you’re displaying DVCPRO HD via the component output of a K2 for example, is the idea that you’re seeing an HD signal (albeit displayed on a less-than-HD monitor) versus having to get the Kona to do an SD down-convert? If that is the case, seems to me that you would actually be able to view the signal at a higher resolution on the 20L5, right? Instead of an SD 525 line down-convert format, you’re watching a 720 line signal displayed on about 600 lines (16×9 letterboxed).
    Does this make any sense? If anyone can enlighten me, I’d appreciate it.
    Best, JIM.
    Jim Blokland replied 21 years, 3 months ago 1 Member · 0 Replies
  • 0 Replies
