Activity Forums Zaxwerks multi core rendering?
  • multi core rendering?
    Posted by Wim Roegels on April 2, 2008 at 7:41 am
    I am thinking seriously on buying a InvPro for AE.
    But is it right that there is right now no support for multi processor rendering?
    Is this planed … because I am not that happy with the Render Performace if I have to turn off the multi core support.
    Thanks in advance.
    Ken Latman replied 18 years, 5 months ago 3 Members · 2 Replies
  • Ong Joseph
    April 2, 2008 at 9:53 am
    Just to add on, I’m currently using 3d layer warps version 1.3. It seems to be rendering very slowly although I’m running on a quad core. Does this product support multi processors?
  • Ken Latman
    April 2, 2008 at 11:37 pm
    I don’t believe ProAnimator as a standalone application uses multiprocessor support. If your using it as a plug-in, AE should be using it in multiple processors if you have that turned on or have Nucleo Pro.
    It might as a standalone application address more RAM that AE currently does.
    How long are your compositions? You might want to breakup your animations into smaller chunks. That is one work around.
