Activity Forums Apple Motion Multi color text layer changing to one color
  • Multi color text layer changing to one color
    Posted by John Czerwinski on September 27, 2011 at 11:32 pm
    I’m having template problems with my text changing from two colors to one in the same layer. For example XXXyyyyyy.XXX say X = white and Y = gray. The graphic will either turn all white or all gray. The problem seems to happen after I render the graphic in FCP7. If I “open in editor”, save the file in Motion and go back to FCP, render again. The problem goes away. It doesn’t happen all the time, but it is annoying. I was wondering if anyone is having this problem.
    Thanks for your time,
    John
    John Czerwinski replied 14 years, 11 months ago 1 Member · 0 Replies
  • 0 Replies
