Activity Forums Apple Final Cut Pro Legacy Multi Clip Won’t Play All Screens
  • Multi Clip Won’t Play All Screens
    Posted by John Smith on October 8, 2006 at 9:17 pm
    I’m editing clips with the Photo Jpeg compression, with a frame size of 384×216. I can’t get the multiclip to play with all the screens showing. When I hit play it goes full screen, then when I stop it, it goes back to the multi screen view.
    Is this because of the frame size or compresson I’m using?
    John Smith replied 19 years, 11 months ago 2 Members · 2 Replies
  • Dan Riley
    October 8, 2006 at 9:45 pm
    If you have rendered the sequence and have a blue line at the top,
    you can’t play back the multiple screens at the same time.
    See if that’s the problem.
    Dan
  • John Smith
    October 9, 2006 at 1:08 am
    No blue line, just a grey one. Even before I bring the multi clip to the timeline it won’t play all the screens, it just goes full screen to the active angle. It works perfectly with the high res DV footage, but this is the first time I’ve tried it with this compression.
    Thanks for your thoughts
