Activity › Forums › Apple Final Cut Pro Legacy › multi clip timeline rendering problem
  • multi clip timeline rendering problem
    Posted by Tom Mooney on January 15, 2008 at 11:02 pm
    We have a program that was assembled in the multi-clip mode on a DV time line. The time line is giving us the light green shade at the top and will not export unless it is either rendered or saved as a self contained movie. These are DV clips on a DV time line with no filtering so it should not have to render. It has to be the multi-camera clip on the time line. Any suggestion on how to export that without rendering?
    David Bogie replied 18 years, 8 months ago 3 Members · 2 Replies
  • Thom Obarski
    January 16, 2008 at 12:03 am
    You could change your RT settings to unlimited/and or right click on the MC clips and click Collapse Multiclip.
    Hope that helps!
    ~Thom
    “This is post, you can’t fix it after this.”
  • David Bogie
    January 16, 2008 at 8:08 pm
    Yar.
    Multiclip IS an effect.
    bogiesan
